U-shaped log k vs organic fraction plots for RP columns
Posted: Fri Jun 15, 2012 6:01 pm
For even C18 columns, the plot of log K as a function of volume fraction organic becomes U shaped at higher organic concentrations. This effect is more pronounced for some RP columns (pentafluoro) than others. However, the underlying these seems to be that that the silica support necessarily permits this unexpected "HILIC-like" (perhaps also ion exchange) mode of retention.
What about non-silica based supports, such as PS-DVB? Surely you would not expect retention factor to INCREASE at the upper extremes of organic volume fractions, presumably because there is no hydrophilic nature to the underivatized ps-dvb support.
What about PS-DVB functionalized with a high exchange capacity ion exchanger, such as PS-DVB +quarternary ammonium group? Would hilic retention at high MeCN% be possible then?
If not, could, perhaps, co-polymers of hydroxy-methyl, PEG, or cyano- substituted styrenes permit HILIC column made from ps-DVB co-polymers?
