Anyone running Shimadzu 14A with TCD/FID in series?
Posted: Sat May 28, 2005 3:21 am
The FID on our GC hasn't ever been used. Looking to run CH4, and would very much like to analyze for CO2 in the same samples. I assume it's possible to run TCD and FID detectors in series since the former is non destructive. Is this setup routine?
I'm using a Shimadzu Chromatopac integrator, and Porapak Q (?) column. Is there anything I should know that will make this easier?
Thanks, Dave
Thanks, Dave
