Amino acetates and NaCl
Posted: Fri Jun 01, 2012 7:06 pm
To those more learned in these issues,
I have a system of amino acetates and am using a Dionex Surfactant column for separating them. I am running ACN and 100 mM NH4Ac buffer at pH 5 with an ELSD detector. Injection of simple NaCl gives 2 peaks and I do not seem to be able to pick up simple acids (acetic, chloroacetic). So it boils down to a few simple questions:
- why does NaCl give two peaks
- what can I do to start detecting AcOH and chloro-AcOH
- is there a better column out there for separating amino acetates/acids?
Thanks in advance for those who may provide insights.
G.
G.
