Can hypercarb dry out
Posted: Wed May 30, 2012 6:24 am
I have lurked around these forums for a while but never posted. I did do a search and read as many threads as I could but I can't seem to find info on this problem. I am using a hypercarb column, heated at 60C. Mobile is water and 50% ACN. I am separating oligosaccharides. I had a method that was working beautifully to separate my substrate from my products. Anyway, I was sharing my HPLC with another lab and the other guy (I swear) took my column off to put his on. He left it in the heater, with no column plugs. I thought that the column would be fine given the nature of the packing, but now I am getting very little or no retention. Any thoughts?
Thanks!
Thanks!
