Help with HP flowcalc software !
Posted: Thu May 26, 2005 8:35 am
I'm quite beginner with GC (i usually use LC/MS when possible).
I try to know the good parameters for my analysis, we are using a PE autosystem XL GC with a VarianVF5 colum 0.25mm,0.25µm-15m flushed with He. We use the colum between 50 and 200°c and the detector is an FID. What must be the carrier gas flow ? i tried to calculate with the HP software but i don(t understand every fields to fill: i.e Inlet Temp (C) is Injector temp ?, or Inlet pressure(gauge)= ?, Is Outlet flow the carrier gas flow i must setup ?
Please Help me !
Please Help me !
