Please help!!! My problem with Ibuprofen
Posted: Sun May 20, 2012 2:02 pm
Hi everyone, I have been analyzing Ibuprofen and have some problems:
1. I use the buffer prepared with H3PO4 (0.05M) then adjusted to pH 2.0 with NaOH. My Retention time is about 23-25 minutes. The RT is very stable but Tailing Factor is too big: 2.5 whereas the required tailing factor is below 2.0.
2. To resolve the problem, I changed the buffer prepared with NaH2PO4 (0.05M) and adjusted to pH 3.0 with CH3COOH. The result is fabulous, the Tailing Factor reduce to 1,8 and the RT is about 22-24 min, the reproduction is good. But when I change pH to 2.0 with the same modifier, everything is ok except the RT which reduced to 10 min. Any reply will be appreciated!
