Column overpressure
Posted: Thu May 17, 2012 10:06 am
Hi
I've been working on an experiment in which my mobile phase is a gradient method consisting of acetonitrile and buffer (ammonium acetate in water, pH 4.6). I am using an Inertsil ph-3 10 cm column, and it runs fine, but when I want to run it again after a completed sampleset, the system goes over pressure. This happened with two columns now. At the end of the first succesfully completed sampleset i washed the column with Acetonitrile:water (1:1) for 60 minutes, and even now I have been washing it with methanol, water mixtures, acetonitrile mixtures and even reversed the column, yet nothing seems to help. Any help would be great!
