Oxygen related peak
Posted: Tue May 15, 2012 4:17 pm
I am seeing a peak in my chromatogram that I've determined to be caused by an elevated oxygen level in the sample. I am trying to mitigate its impact by altering the amount of dissolved gases in the mobile phase and/or sample. The link suggests that a negative peak can be obtained if the mobile phase contains more dissolved oxygen than the sample. This doesn't make sense since the lack of something does not produce a peak directly. Is it more likely that the peak attributed to oxygen is actually a solvent peak with a higher concentration of dissolved oxygen?
For anyone with experience on this issue:
Is it easy to nullify an interference related to dissolved oxygen by 'balancing' the absorbtion of the sample and mobile phase?
http://www.shimadzu.com/an/hplc/support ... 37lab.html
