Ultimate3000 Flow manager error
Posted: Tue May 15, 2012 9:59 am
Hy everyone!
I am having difficulty with the system Dionex Ultimate3000. On the panel of Flow manager appears error "Flow control valve failure" or " Flow control valve limit" on panel. In Cromeleon Log file error is "flow control valve failure or column path not tight" or 'insufficient pump flow". When I disconnect column from switching valve, there is no error, when I reconnect column appears error message. When error appears the running program is aborted. Chromatograph operated by HyStar. I washed with isopropanol system to avoid the presence of bubbles, pressure in the system does not jumps. What could be the cause of the error?
Alena
Alena
