Column Selection....
Posted: Tue May 08, 2012 11:38 am
I currently use an Agilent HP-ULTRA 2 to quantify Polyethylene Glycol in Carbowax.
I'm working on a method that will look at quantifying Propylene Glycol in a HydroGel. I've been getting good results from the PoraPLOT-Q column.
To avoid disturbing the system routinely, I was wondering if there is a suitable column I could use for both tests?
Regards.
Regards.
