Nitrogen generator for TurboVap evaporators
Posted: Tue May 08, 2012 10:35 am
My lab would like to source a nitrogen generator to supply two Zymark TurboVap Evaporators simultaneously. According to the specification, each evaporator requires 140L/min nitrogen if all 50 nozzles were used.
Do any expert know a nitrogen generator with built-in air compressor to supply sufficient nitrogen for 2 TurboVap evaporators that is small in size and low in noise level and supply a N2 purity up to 90%?
Thank you.
Thank you.
