Partition Coefficients of IPA,MeOH and ACN in water and DMSO
Posted: Mon May 07, 2012 7:05 pm
by Mike H.
Is there a resource somewhere that lists partition coefficients of common analytes in water and DMSO? For instance say I wanted to compare the partition coefficients of MeOH in both water and DMSO. Where would I find this?
Re: Partition Coefficients of IPA,MeOH and ACN in water and
Posted: Mon May 07, 2012 8:10 pm
by chromatographer1
I do not recall ever seeing anything like this, except for solubilities of solvents into water.
It would be an easy experiment to perform, but it could get complicated: different temperatures, range of volumes, etc. And of course, some solvents are fully immiscible with each other.
Are you asking about vapor phase partitions from a solution, as in head space analysis?
If you decide to do the research, release the results publicly, would you?
best wishes,
