Linear Curve with Empower2
Posted: Fri May 04, 2012 8:03 pm
by greg7137
I am trying to make a linear curve using peak areas of my sample. I injected a sample at 5, 10, 20, and 50uL which the sample contains 4 peaks. I want to plot each peak area for each level to get a curve and an R squared value so i can get 4 curves and 4 R squares.
I cannot remember how to do this, I just got back from a 4 month break away from Empower and these little things have left my mind on how to do them.
Thank you for the help
Greg
Re: Linear Curve with Empower2
Posted: Mon May 07, 2012 8:41 am
by aceto_81
If you had dealed in the past with Empower, this should fairly easy:
Put your samples as standards, plug in the amounts for each peak, go to review and push calibrate.
Ace
Posted: Tue May 08, 2012 2:47 pm
by greg7137
Thanks for the help. I knew it was really something simple, I just could not figure out what i was missing.
