Chromeleon 7: data processing
Posted: Fri May 04, 2012 12:56 am
I am using the chromeleon 7 software and obtained a nice integration method. The peaks are reported in rel% area as acidic, main and basic in the integration. However, the number of peaks change for certain samples which are then not visible in the sequence summary. Is there a way to group peaks based on their retention time to avoid this problem? How can I present the peak's group result in the summary? Thanks
