Methanolic size exclusion
Posted: Thu May 19, 2005 1:05 pm
we are synthesising block copolymers and are routinely doing size exclusion on these. Normally we use water, DMF and THF, depending on solubility.
A certain class of these polymers are only soluble in water and methanol however. Water is not working properly for size exclusion at least by the methods we normally use.
Inspired by a recent article on related copolymers we consider using methanol as solvent. The article uses a 0.2 M (!) LiClO4 in methanol and polyethylene oxide standards.
Our current problem is that we are not able to dissolve very much in this eluent and we have been wondering if this high concentration is a typo.
Anyway, does anyone have experience in doing SEC with methanolic eluents? There does not seem to be much literature as far as I have been able to find.
Thank you in advance!
Jeppe
Jeppe
