HPLC chromatogram
Posted: Sat Apr 28, 2012 1:56 am
In a HPLC chromatogram for a standard, the peak area is 20000.
2000 times dilution of the standard gave a peak area of 8.
The peak area of this diluted standard is used for impurities limit test (i.e. the area of any impurity must be less than the peak area in the diluted standard, which in this case it would be 8. )
Theoretically,a 2000 times dilution of the standard should give an area count of 20.
Is this huge difference in area count (8 versus theoretical 20) due to the large dilution factor?
