problem with saparation of phenolic acid
Posted: Mon Apr 23, 2012 12:14 pm
Hi all,
I have a big problem with separation of phenolic acid on Poroshel 120 SB-C18 column.
I am trying to divide some phenolics on this column , but the more of them have the same RT. For example, p-cumaric acid, rutin, catechin, caffeec acid appear at 36,7 min. The Mobile phase that I use is A: 0.5 % acetic acid , B: AcN in gradient condition - the first 15 min 20%B, to 40th minute 80%B , to 50 min. 100% B and at 50 min 20%B.
What I should to do ?
Thank you!
Thank you!
