pyrolysis-GC/MS sytem
Posted: Thu Apr 19, 2012 4:38 pm
by s2008
Hi all,
we currently bothered by persistent high BP hydrocarbons carry-over in the pyrolysis-Gc/MS system.
Normal high temperature baking did not work well. Has anybody same experience ?
Re: pyrolysis-GC/MS sytem
Posted: Fri Apr 20, 2012 12:16 am
by HbJ
Please give us details about pyrolysis unit (CDS, Target etc.), your GC conditions, samples etc.
Posted: Fri Apr 20, 2012 1:52 am
by Don_Hilton
Is the carry over from the pyrolysis unit or in the GC?
Posted: Fri Apr 20, 2012 5:02 pm
by s2008
Thanks for your concerns.
For sure we knew the carryover did not come from GC sytem.
The weird thing is that there no any carryover when we ran blank ( no real sample and other same as parameters as running samples).
we are using polyetheylene as QC and the carryover appeared from high BP range.
Posted: Sat Apr 21, 2012 1:10 am
by Don_Hilton
A bit more detail would be helpful. You have no carry over when you run a blank but you have carry over? Please descrive the sequence of runs. What was put into the pyrolisis device and what the chromatograpich result was -- no response, expected response, carry over, etc.
If you will tell what pyrolysis device you use, perhaps someone will recognize the device and perhaps the problem.
Posted: Sat May 12, 2012 12:20 pm
by pooch
Do you use a quartz tube with a filler for your pyrolysis?
It will be useful to know your pyrolysis system (chamber, curie point...)
But maybe your problem is now resolved...
