carrier gas
Posted: Thu Apr 19, 2012 1:44 am
Hi, Everyone
recently i change the mobile gas from He to N2 and makeup gas to N2 too. I also use temperature programme for my FID splitless GC. My question is when i use N2, i set up Purge time is 0.5m,the solvent peak is good, but between solvent and decane, there are lots small peaks in there as if there is comtanmination. However, when i change gas to He and purge time still is 0.5m(purge flow is 40ml/min), i have big solvent tailing.
can you explain why?
thank you very much
thank you very much
