Tube leak testing for the PE TurboMatrix 150
Posted: Thu Apr 05, 2012 2:42 am
Hello all, hope I'm posting this in the right place.
Ok, a bit of a story. I've just restarted work with thermal desorption-GC-MS after a long layoff.
We have a Perkin-Elmer TurboMatrix 150 Automated Thermal Desorber going into a Varian 3800 GC-MS.
The problem (actually one of a few) we have with it is when a tube fails its leak test, the ATD will then try the next tube and if that succeeds, it will continue the thermal desorption process and inject the sample. Because the ATD and the Varian GC-MS are controlled with different software, the sequence we have with the GC-MS will be then be out of step with what is injected from the ATD. When a tube fails a leak test the ATD will then attempt up to two more subsequent tubes before shutting down with an error. The GC-MS acquisition sequence can be well out of step with what is going onto with the ATD. After each run we have to make sure to check the logfile before being sure of what is actually been injected.
Its a ridiculous state of affairs. I can't recall this being the case when I worked with the PE 650 series but may be mistaken (its been a number of years now).
Reading the TurboMatrix manual on pages 309-310 it states that the number of leak test retries can be set between zero and two (two being default, which is what we have) - I wish to change this to zero so if it fails a leak test, the process then shuts down immediately and we'll have no confusion.
My problem is *how* to change this value - the manual says nothing apart from it can be. I've looked over of the preferences/setting/method editor pages of the ATD touchscreen and no luck.
Anyone out there know?
We're getting a Markes system in the next few months but this is our go to instrument until then.
Many thanks in advance.
