Benzene peak shape issues - residual solvent method help
Posted: Tue Apr 03, 2012 11:01 pm
Good day all,
I am working to develop/validate a direct injection method for residual benzene content within pharmaceutical intermediates. The test article is dissolved in DMAC, run on RTX-624 (30m x 0.32mm x 1.8µm). In short, I have found that my peak shape suffers severely as split is stepped down to a split-less configuration or larger injection volumes are made.
Initially I believed there was a second compound co-eluting with the benzene, as the peak did not present typical tailing shape. Rather, as the peak dropped off towards baseline, approximately half way down it would 'bludge' out and tail off.
A split of 1:10 does not demonstrate the peak shape (approx USP Tailing 1.3), but moving down towards split-less it appears.
My attempts at resolving this issue to this point have not provided an acceptable outcome. Too many parameter adjustments (pulsed splitless, temperature settings, injection volume) have been evaluated to include all here, initially. I believe that the larger injection volume or split-less mode are not producing a narrow enough band on the column.
Does anyone have insight on trace benzene analysis WRT peak shape?
I very much realize that without my parameters the input may be limited... please let me know if I can provide more details.
Thanks in advance for any replies!!
Cheers,
Jeremy
Cheers,
Jeremy
