Quantification using internal standard... a protocol
Posted: Mon Apr 02, 2012 4:53 am
Hi Everybody!
It has been a long long time since I last visited the forum. But I have a fairly straight forward question concerning quantifying compounds in extracts.
I work on sandalwood plants; how and why they produce their essential oils. In my most recent experiment I have 6 time points, 4 biological replicates and two experimental conditions - treated and control. After the initiation of the experiment, I randomly select four plants where I grind various tissues up, freeze them and analyse them for all sorts of stuff - one of which is essential oil production.
Now, I have small bags of ground stem and root tissue which are air-dried. I want to know what the concentration of sandalwood oil components in the sample is. In the past I have weighed the sample, extracted in solvent with a known amount of internal standard, and run these on the GC. Here is where my problem comes in.
The determination of a detector response factor relies on being able to get a pure compound (the analyte) and seeing how it's signal relates to it's concentration relative to that of the internal standard. I have two problems - Sandalwood oil has well over 50 compounds in the mixture and standards don't exist for the vast majority of these.
I had one idea - how about taking pure distilled sandalwood oil and preparing an external standard curve. From the most dilute to the most concentrated, I would sum the area of the entire chromatogram and treat this as one analyte. Then I would run the extracted samples, determine the unknown oil concentration as per the standard curve, and work back to the final concentration based on the amount of material I extracted.
An alternative is to use an internal standard with a response factor calculated based on the sum of all components being one analyte 'peak'.
Which do you think is a better representation of the actual concentration of compounds in my tissues?
Cheers,
Chris
Cheers,
Chris
