LC Column Options
Posted: Sun Mar 25, 2012 2:01 pm
by chemboy831
Morning Everyone,
I've been running several assays on an Agilent Zorbax Eclipse Plus C18 column (2.1mm x 50mm x 1.8um) and i'm looking to try out similar columns for other manufacturers. Any suggestions? I was told Waters UPLC columns won't be compatible with my Agilent 1290 LC. Is that correct?
Thanks.
Chemboy831
Re: LC Column Options
Posted: Sun Mar 25, 2012 4:00 pm
by Hollow
Morning Everyone,
Thanks.
Chemboy831
UPLC columns are rated "just" up to 1000 bar where your 1290 can go up to 1200 bar. So just slow down your flow rate a bit.
As with any other column, use adjustable fittings so you can make a void free conection.
apart from this, they are columns like others.
(Of course you won't be able to use the Acquity eCord function... ;-) )
If you want to find similar (or totaly different) columns, have a look at the USP column equivalency database and use the PQRI model
Link: http://www.usp.org/app/USPNF/columns.html
>"compare columns" > scroll down to "PQRI database"
small "F" value = similar, big "F" = different
Posted: Mon Mar 26, 2012 10:14 pm
by danko
Thermo Fisher make similar columns (1.9 um). I think they are more similar to the one you use than the Acquity columns. The latter's stationary phase support is not pure silica but BEH, which changes "the game" a little bit.
Posted: Tue Mar 27, 2012 2:48 am
by AA
There are 3 basic Acquity columns (< 2 um).
BEH - bridged ethyl hybrid
CSH - BEH with a charged surface (Charged Surface Hybrid)
HSS - High Strength Silica
There are a couple of C18 bondings within each particle.
Poke around the Waters web site for more details.
And yes, you can use them in a 1290 but watch the upper pressure limit (as was mentioned previously.
Posted: Thu Apr 19, 2012 2:03 pm
by bverma
I just saw your post for looking for an equivalent column for the Agilent Zorbax Eclipse Plus C18 column. Perhaps you should try Imtakt USA's Cadenza CD-C18 column. This column is a 3 micron column that offers 25-50% less back pressure, high column efficiency, better separation of hydrophobic compounds, higher steric selectivity, and a high plate count at a low flow rate. This column also comes in a HT/UP version....the HT version has a pressure limit of 500 bar, and the UP version has a pressure limit of 1000 bar. The HT/UP versions can be used on a UPLC system, you just have to by the universal end fittings from Waters.
More information about the Cadenza CD-C18 column and the HT/UP versions are below:
http://www.imtaktusa.com/site_media/fil ... CD_C18.pdf
http://www.imtaktusa.com/site_media/fil ... and_UP.pdf
For more information, please contact me at bverma@imtaktusa.com.
Hope this helps!
Posted: Thu Apr 19, 2012 2:38 pm
by Klaus I.
User 'chemboy831' is operating an Agilent 1290 LC.
Posted: Thu Apr 19, 2012 3:04 pm
by bverma
Imtakt's columns can be used on the Agilent system that you mentioned, you should not have to buy any end fittings.
Posted: Thu Apr 19, 2012 3:05 pm
by Klaus I.
Dear Hollow,
if I remember correctly, the recommendation (some years ago ;-) ) given by Waters for UPLC BEH columns below 1000 bar, only the HSS phases were specificated for 1000 bar, but I may be wrong on this.
Best regards
Klaus
