Peak Fronting
Posted: Tue Mar 20, 2012 12:13 am
I recently received a Waters 2795 from donation, which passed PM just prior to my receiving it. I also have a brand new column that I tested on another system with the test mix and know that the column is in perfect condition. Once I set this 2795 up, I ran the test mix on this new column and I am seeing a significant amount of peak fronting. Since the method is tried and true, as is the column, I am uncertain what could be causing peak fronting. One further note is that my diluent is the same as my mobile phase. Everything I know about peak fronting usually points to one of these as the probable factor influencing the poor peak shape.
The only other thing I can think of is that maybe my tubing isn't in connected properly and is causing a void between the tubing and the inlet or outlet of the column. I'm almost 100% certain this is a system issue of some sort, I just can't think of anything else I can pinpoint to be the problem. I was thinking I would re-plumb the system tomorrow, unless anyone else could give me any other bright ideas that might be reasonable options. This is my first time using a 2795, so I didn't know if there was something inherent to this type of LC that I needed to be aware of when trying to troubleshoot this issue. Any other insight would be greatly appreciated!
Thanks!
Thanks!
