Good afternoon, I have a problem with my mass spectrometer is a turbomass, the problem started the day today, to try to light it does nothing, not even turn on the LED status indicator, only makes a noise on the right as if a relay is activated but not power-up, no problem if the source is electronic or has any component that fails, the computer is dead, I would advise to start reviewing or more to support me in this problem.
Greetings and thank you very much beforehand.
