amino acid analyses with BSTFA
Posted: Thu May 12, 2005 3:27 pm
Hi !
I'm new in this forum but I use to read the posts.
Today I would like to ask a question. I need to analyse an amino acid which the structure is near from glutamine in a plant extract.
I can elute it on the Zic pHILIC from SEQUANT with a retention time of 12 minutes, but in my plant extract I have another compound with a very near structure, and the two coelute.
So I would like to try in GC but I don't have a lot of experience in GC . I read that the amino acid can be derivatized with BSTFA in general doc on GC. I have also a DB 5 column.
Does anyone know conditions for the derivatisation ?
Which solvent compatible with BSTFA is used to dissolve the amino acid?
Thank you for help
Thank you for help
