Dionex help on contamination of AS9HC.
Posted: Fri Mar 16, 2012 1:42 pm
Hello
I've ten years experience in IC included my degree on validation of IC methods.
I've experienced a crytical problem with my new ICS1100 running with AS9HC & carbonate 9mM eluent.
i try to describe the situation.
the system is new, it worked fine for a few months but now i experienced a drammatic decrease in retention times of all anion peaks.
It starts with change in resolution of sulphate/Posphate... continues with sovrapposition of Nitrate with sulphate+posphate & ends with death of column.
I use the same eluent & water since 10 years.
Water is bi-distilled & filtered with conductivity usually < 1uScm-1.
Carbonate is (i wish) as pure as possible.
Contaminants that kills colums that i know are:
-CrVI (it's absent i've controlled it AA it's >LOD in flame i can control in A.A./E.T.A. but i want to exclude ppB levels i don't believe it's present
- grease (the system is completly new ics 1100 it mustn't have problems with grease i wish
- all the lines for eluents are inert
- i've checked eluent for presence of fe3+ but it's < LOD in flame
- i've thinked about free Cl2 in water but it's bidistilled water...
& i don't know what's the effect of cl2 on PSDVB polymers
i don't know what to look for.
It kills AS9-HC & i've fear that it contaminate the system!!!!!
What should it be?
I'm desperate i'll request a dionex visit but i don't know what's the problem.
The eluent is prepared with the same procedure (column data sheet) since ten years: mother solution .... diluition to 9mM carbonate.... etc....
HELP ME.
What should it be?
HELP ME.
