Primesep type columns and MS
Posted: Thu May 12, 2005 10:17 am
I understand that columns with embedded polar groups are not particularly useful for HPLC-MS because they give rise to a lot of background.
I also understand that it is not that these columns lose stationary phase more readily but that the stuff that bleeds off ionises readily in the MS (at least in ES mode).
Does the same apply to columns which have bonded ionic groups like Primesep ? A simplistic view would be that if the column contained negatively charged groups for the analysis of positively charged solutes, then bleed of this group from the column might be a problem in negative ion MS but not positive ion MS, and the reverse for columns with groups of oppoisite charge. I would welcome any comments from SIELC or anyone who has experience of this issue. Comments on the EPG bleed issue would also be appreciated-did I get it right above?
