LC Column Bleed
Posted: Wed Mar 07, 2012 7:25 pm
Columns like the Acclaim WAX-1 and Obelisc columns give alot of bleed under ESI(+) conditions right out of the box. Conditioning these columns at 35C for several hours using 20 mM Ammonium Acetate buffer and acetonitrile (tried 10, 50 and 80% B) still does not seem to make much of an impact on the column bleed. Also tried 50mM AmAc for about 1 hr but still higher background under ESI(+) mode than is typical for a reverse phase column. Last I looked the Obelisc columns were QC's using TFA - a double whammy - aahh!
Does anybody else have these same experiences and how do you solve this problem - condition overnight, conditions for days or just give up with these types of columns for MS work? Any better MS compatible alternatives for mixed mode? BTW, I do not want to use any ion pairing reagents such a HFBA or TFA.
