Which analytical technique (s)????
Posted: Tue Feb 28, 2012 11:26 am
I am working on cardon dioxide reduction and need to identify and quantify the products, I don't know exactly what will be in the reduced solution. But, most probably the solution will contain tiny amounts of :
methanol, formic acid,methane and formaldehyde in aqueous phase, I also expect the reactants to be present in small amounts: The reactants are acetate, KCl and pyridine in deionised water at PH=5.2.
Which analytical technique (s) is suitable in this case to both identify and quantify the mentionable compounds? Do I need to
Can anyone help me with this please?
Thank you in advance.
