Read sequence and method files
Posted: Fri Feb 24, 2012 12:18 am
I am sorry in case this isn't the best place to ask this question. Unfortunately, I am pretty new to the field and I think few of you might have found yourselves in the same boots as I am in currently.
I have a scenario where I would like to read and decode the sequence and method files written by EZChrom HPLC. Unfortunately these files are written in binary format. I need to do this using a programming language. So its more of a computer science related side of EZChrom HPLC.
Because there are several HPLC vendors, each one of them coming up with his/her sequence and method files, I was wondering if there was a standard format to write these files so that they remain usable across different vendors and machines. Any pointers?
Thanks you very much for your time.
