MRM and retention time
Posted: Thu Feb 23, 2012 10:39 pm
I have worked on developing method for a parent compound and its 2 metabolites, all have different molecular weight (M, M-2 and M+14); hence different MRM pairs.
I was able to separate the parent and one metabolite but the second metabolites is eluting at the same retention time of the parent (but in a different MRM channel/transition from parent ) .
Is there a problem with this assay (that I am overlooking)?
Do I have to spend time on method development to make the 2nd metabolite elute at different retention time even though the MRM transition is different.
Any help/advice is appreciated!
Thanks much
Thanks much
