Hi Bjorn,
Finally came up with a software work around, unfortunately can not use the GcEad software.
I wrote an Excel / OpenOffice spread sheet that can create a CSV format that can be opened by Openchrom
http://www.openchrom.net/ (need to be connected to the internet to download conversion plug-ins)
Basically steps are follows:
1) export the EAD data to a CSV file from GcEad. eg as EAD1.csv
2) Open the EAD1.csv in excel
3) Copy the column of data into column A of the spread sheet I wrote formulas in.
4) create a txt file, and open in notepad.
5) Copy the data from column F ( I hid columns B to E), from spread sheet I wrote formulas in, into the txt file.
6) save the txt file
7) rename the txt file, so it is now. eg NewEAD.CSV
(note that is now a CSV file)
8 ) open up NewEAD.CSV in Openchrom.
9) open Chemstation data in Openchrom.
10) and compare.
To view the EAD data in Chemstation:
11) In Openchromopen, save the NewEAD.CSV, as a
CDF, eg EAD1.cdf
12) Copy EAD1.cdf into the GCMS data directory, eg evaldemo.d.
13) Open the pre_post.ini file in the evaldemo.d directory in notepad ,and paste at the end and save:
Code: Select all
ConfirmFile=\EAD1.cdf
ConfirmType=cdffile
sectimestamp=unrecognized
14) Open evaldemo.d in Chemstation, and it will be a TIC, if software has align functionality it should work.
To view the EAD cdf data in AMDIS:
15) Open EAD1.cdf file, the in the window right click file->open, then change file type to Agilent, and load evaldemo.d.
16) Only click on the evaldemo.d window for spectra, as clicking on the EAD1.cdf file will only give the fake 84 ion.
If you are interested in the Excel/OpenOffice spread sheet that I wrote email me,
N.B. select column headers during all copy and paste functions, so there are no remains of previous data.
What the Spread sheet does:
1) User defined Hz rating, as need to generate RT in milliseconds and minutes
2) ALL voltage values up shifted up so the lowest negative value is now 0, negative values are not plotted in Openchrom, Chemstation or AMDIS when using MS data.
3) Voltages are converted to uVolts, so can actually see discrete values.
4) formats header and data values,
5) Hides rows with no data, so can copy and paste column F directly into a CSV text file.
if 65535 rows are not enough, then need excel 2007
http://excelsemipro.com/2011/04/spreads ... r-windows/
or Open Office.
http://wiki.services.openoffice.org/wik ... er_of_rows
why I as asking about your other equipment, is the theoretical use of recording the values of temperature inputs, as chemstation allows you to store eg oven, detector temp,injector temp, EPC pressure, as signals, (depending on resolution (discrete points) of course),
I doubt that that will pass any OHS risk assessment, Voltages
chemstation
at
gmail
com
Alex
