heeelp with Class-VP sofware!!!!!!
Posted: Tue Feb 21, 2012 3:27 pm
hi everyone, could you please help me
I'm using a Class-VP software. Long time i worked with TCD detector for analysing the peaks.Now i need also FID detector.When i started to make changes in Configuration box (in the Main Menu box Class-VP chromatography Data System) to turn the channel, detector, for FID it works. but now i can't make changes back to use the TCD detector. Could you please tell me where is the problem??
thanks !!!!
thanks !!!!
