Amino acid analysis calculations
Posted: Sun Feb 19, 2012 6:29 pm
Dear all,
We are using amino acid analysis (post column derivitization) for quantification of a certain purified protein to be used as an in-house reference, and I have a question about the calculations derived from such assay. As this assay uses a standard composed of quantified amino acids possible to detect and analyze by rhis method, the result is in terms of nmol (or pico mole). As we need to convert this to ug or mg, this is usually done by equations eg. 100 pmol of 100 kDa protein = 10 µg. In case of our protein, it a calculated molecular weight (based on it AA composition), but a bigger weight including its glycosilation. Which molecular weight should be used in such calculations? and can I find this explained somewhere on any website/publication?
Thank you
Thank you
