Diethylene glycol in glycerin
Posted: Fri May 06, 2005 4:41 pm
Working with the USP 28 GC procedure I found the following problem: The signal obtained from an spiked solution of glycerin with diethylene glycol is about ten times the signal from a pure solution of diethylene glycol of the same concentration. The glycerin itself is free from diethylene glycol. The procedure uses a special liner ( inverted cup or speril liner) and I haven´t it. Could anyone help me with my problem?
