Pressure, temprature and flow rate in GC
Posted: Fri May 06, 2005 4:17 pm
I read an article about why carrier gas flow rate decreases when oven temp increases without changing the inlet pressure. The author talked about how carrier gas viscosity increases with increasing oven temp, therefore it causes the flow rate to decrease. Any other opinions about this? Thanks.
