Perkin-Elmer TOTAL CHROM SOFTWARE
Posted: Thu Feb 09, 2012 9:40 am
by jakebarham
I am trying to set up a pdf creator so that the report that is generated in TotalChrom is created as a .pdf file.
I have set the PDF printer in the sequence and also set it as the default printer. The process is sent to the PDF printer but then immediately disappears and does not do anything. This shows that there is a connection between the software and the printer.
The PDF creator works if I print a file but does not work during instrument run time.
Has anyone had any experience with setting up a pdf printer in TotalChrom software?
Thanks in advance for your help
