DMSO in SPME GC-MS
Posted: Sat Feb 04, 2012 8:37 pm
Dear All,
I propose to dissolve my water insoluble samples in DMSO for subsequent residual solvent analysis by SPME GC-MS.
I have not used DMSO before. Is there anything I should bear in mind prior to using it? How does it handle? I guess by definition its not volatile... From initial searches I know that I need headspace grade.
I intend to use incubation temperature of 80degC and typical GC settings of:
5 type column helium 1mlmin 50:1 split temperature ramp from 50 to 180 at 5degC/min.
Thanks in advance.
WK
Thanks in advance.
WK
