Explosive!
Posted: Fri Feb 03, 2012 4:25 pm
by Fernando
Hi all:
We have problems purchasing ammonium perchlorate (Explosive!) do you think we can replace it with ammonium acetate? We have a mobile phase with ammonium perchlorate in methanol about 1 g/liter.
Any suggestion will be wellcome!
Re: Explosive!
Posted: Fri Feb 03, 2012 6:44 pm
by DJ
The perchlorate ion is more soluble in high organic than other salts. What is your method, column?
Re: Explosive!
Posted: Fri Feb 03, 2012 9:09 pm
by oscarBAL
Hi fernando; maybe you can find some information here:
viewtopic.php?f=1&t=17547&hilit=perchlorate
Oscar.
Re: Explosive!
Posted: Fri Feb 03, 2012 11:20 pm
by Hollow
if the perchlorat ion is not used for a known reason others than as buffer salt, it probably should be replaceable with ammonium acetate or formiat or others but keeping th pH constant.
If the perchlorat is indeed needed, why not use perchloric acid and ammonia and mix/titrate them in the proper ratio?. I guess, these solutions are less hard to purchase, but you would introduce water into your methanol...
Re: Explosive!
Posted: Fri Feb 03, 2012 11:27 pm
by Vlad Orlovsky
Just make it yourself by mixing ammonia and perchloric acid (be careful doing this)
Re: Explosive!
Posted: Thu Feb 09, 2012 12:35 pm
by Fernando
Hi all
Sorry but I was enyoing a few days out of work, the method is for cinnarizine using an RP 18 (250 x 4.6 mm) 1 ml/min. @ 254 nm.
And the final concentration fo ammonium perchlorate is 0.02 mg/ml in methanol for mobile phase.
Thank you for your help.
