5970/5890 hardware/software compatibility questions
Posted: Wed Feb 01, 2012 2:33 am
by m.finnBMBM
I want to know what the software limitations are for a 5970/5890 set-up. Can this set-up work with a XP as the OS? Can the 82341 GPIB card work with XP? What limitations for ChemStation versions are there? I am just having a very hard time finding any of this information. I would be very grateful for any leads. Thanks.
Re: 5970/5890 hardware/software compatibility questions
Posted: Wed Feb 01, 2012 2:49 pm
by Bigbear
The last version I used with your hardware was using NT as the os. I used environ quant B.?? It had to be configured by a secondary vendor to work. I think that vendor was CSS out of the middle part of the USA ( Kansas I think). This was done about 20 years ago so the grey cells are fuzzy.
If you are in the states, Call AO 800-842-5742 as they deal with older Agilent/ HP equipment.
