normal autotune report ? high h2o values mean?
Posted: Mon Jan 30, 2012 5:55 pm
Hi
I have a refurbished Agilent GCMS 6890/5975. I am new to GCMS and ran an autotune, but realized I don't know what the various things on the report mean and that I also don't know what normal values are.
What values are really important and what should the normal values for those be?
For example the H2O is at 4%. Where I worked previously, 4% was not good and we would report it to the person who was in charge of the GCMS, but now that person is me. We also ran the autotune every day. I've tried to look for leaks and cannot get the 4% to go down. i tried to bake the oven at 250degC and that also did not do anything for lowering my water %. I do not know what to do so any help would be great. I do not have a transfer line though I did try to lower the temp on Aux 1 to see if that would help. It did -though I don't know why. Can anyone explain this to me?
I looked in the history of the instrument and no autotunes have been run on the instrument since September. I'm new to this company but it seems that the person before me never ran an autotune. I have seen wlsewhere ont he forum that autotune should be run monthly once the machine is set up properly, but I'm not sure that the machine is set up properly. Last week in my search for a leak, I found a loose nut between the inlet and the column. That made the O2, N2 values go down, but the water was still around 4%.
thank you for any help you can give me.
