Flow switcher [June 4, 2004]
Posted: Tue Aug 24, 2004 10:39 pm
By James on Friday, June 4, 2004 - 01:19 am:
Hi. We have a waters 2695 controlled LC/MS . We have been injecting samples which have lots of "biological rubbish" in them - even after MeCN extraction, which of course is no good for our mass spec - cleaning is becoming a nightmare. We think a flow switch would be a good idea as the rubbish generally goes straight through the column in the first couple of minutes before our drugs elute.
I know that the 2695 can send event-switch signals at specific times, so I am wondering if anyone knows of a good (reasonably priced) flow switcher out therewhich we can hook up to the 2695. This way our mass spec would stay clean for much longer
Thanks.
James
By Anonymous on Friday, June 4, 2004 - 05:31 am:
James,
Might I suggest you talk with Valco, they have a nice variety of electropneumatic and electrically switched valves that would suit your purpose. I have used some before to make a homemade fraction collection system. The valves seemed very relibale and easy to use.
website = www.vici.com
P.S. Their folks are very helpful also.
Mark
By Anonymous on Saturday, June 5, 2004 - 10:11 am:
also, check out:
http://www.rheodyne.com/products/fluidi ... /index.asp
Thanks.
James
James,
Mark
also, check out:
