Sacrficial Base (Ion Suppression)
Posted: Sun Jan 29, 2012 3:38 am
Is it necessary to Use TEA when my buffer pH is 2.3 and my analytes are acidic in nature ?
In my case, the peak shape become good with TEA when compare to without TEA. But I didn't understand Mechanism of TEA in lower pH. Because silanols pKa is around 3.8 (so at pH 3.8, Silanols will be 50% ionised) and as we decrease the pH, ionisation of silanols will decrease. So i didn't see any strong reason to use TEA in my case though its giving me good peak shape
While pH is 2.3, is TEA bind with the Silanols
What about using Trifluoroacetic acid? there can be any benefical effects in peak shape? I need the mechanism how they are going to act ?
