SIM programming with ion pairing agents.
Posted: Tue Jan 24, 2012 2:55 pm
Hello All,
I have a method for phosphonates using an ion pairing agent (TEA or NNDHA) C18 column that is proven on a CAD. I need to adapt the method for use on a single quad MS.
My analyte masses are 204.5, 268.9 and 296.85 with NNDHA having a mass of 129.25.
Am I correct in thinking that I just need to program SIMS to look for the combined masses of the analytes and the ion pairing agent? (Plus a window to see to what degree these ionize.)
Is a better approach to start with a broad SIM and start to reduce the window to fine tune down to just the analytes of interest?
I'm using Xcaliber on a Thermo MSQ. Will the ion pairing likely survive electrospray ionization and a probe temp of 300C?
What about intentionally trying to break up the ion pair and just look for the raw analyte? Should higher needle kVs or higher temps do this?
As you can tell, I'm fairly new to MS.
Any guidance is greatly appreciated.
