problem with gases detection
Posted: Tue Jan 24, 2012 2:53 pm
Hello everyone!
I'm Maria and I'm new in the forum. I find it very interesting!
I have a problem since I need to add Kr and H2O in my system and Kr interferes with the CH4 signal so I cannot get separated peaks in the chromatogram while I cannot detect the H2O.
I usually follow CH4 in the FID but it is also detected in the TCD so it's there where Kr and CH4 are solaped.
My carrier gas is Ar.
So the common problems are Kr is solaped with CH4, O2 with CO, He with H2 (in the TCD).
I'm currently using a Hayesep D column 3m, 1/8" ID, 100/120 mesh, I thought in getting a longer one but I'm not sure if that gonna help.
I tried changing the method but it didn't help.
Do you have any idea if another column would be better? or what parameters could be changed in the method to get all the compounds separated?
Thanks in advance,
Maria
Thanks in advance,
Maria
