Experiment design
Posted: Wed Jan 18, 2012 2:09 pm
My project is to optimize the conditions of analyzing B vitamins and I am in the process of experiment design. I have some questions that need suggestions from the expert on the forum.
So the parameters for the optimization includes columns (I would like to test about 5-6 columns available in the lab), pH from 2.5-6 unbuffered v.s buffered and finally mobile phase solvent (methanol, acetonitrile and isopropyl alcohol)
-starting with buffered mobile phase at different pH (2.5, 3.0, 3.5, 4.0, 5.5 and 6.0) and B as Acetonitrile for all columns. Then from the results, I will decide the pH range that produces the best results and then rerun with equivalent unbuffered mobile phase for all columns.
-Compare the chromatograms under buffered and unbuffered conditions within the same pH range.
-Determine which conditions (buffered or unbuffered) and which column produce the best results.
-Try other combinations of solvents (methanol, acetonitrile and isopropyl alcohol) and acids (TFA, formic and acetic)
So if I am following this experiment design, right in the beginning I assume that ACN, MeOH and isopropyl alcohol behave the same for all columns, which is not true.
This is the only design in my mind right now. I am still confused about a lot of things so I would like to receive insight and suggestion from the forum. Thanks a lot!
