I would like to ask help from somebody using this instrument. We have problem with our Thermo Finnigan Analog PCB DSQ part (part nr 119590-0022). Thermo suggests to replace the hole part (their policy), which is quite expensive. It seems that we could just replace the resistor R93 that is burned, but we cannot read the nominal value.
If you use this instrument, please let me know. You could help me by reading this resistance from you instrument. I will send the instructions. Our laboratory would be really grateful.
Best wishes,
Krista
krismo1980@hotmail.com
