Dionex ICE column (AS6) question
Posted: Tue Jan 10, 2012 10:32 am
by lynzjm
Hi all,
We're using a Dionex ICE column, recommended eluent is heptofluoro-butyric, we will use hydrochloric (we know the background conductivity will be higher) but our question is the regeneration fluid recommended is tetrebutylammonium hydroxide for supression - can we use sodium hydroxide as an alternative?
Many thanks.
Re: Dionex ICE column (AS6) question
Posted: Fri Feb 17, 2012 11:49 am
by Mark Albertson
Hi Lynzjm,
If TBAOH is too costly try TMAOH, don't use NaOH, as the TBA ion is responsible for weak acid eluant suppression, TBA+ OSA– pair has low conductance and is partially Ionized post suppressor
Not sure if this helps
Cheers
Mark
