Connect one Autosampler (Dionex ASM) to TWO systems ?
Posted: Mon Jan 09, 2012 8:31 am
Hello!
I currently have 2 Dionex DX300 chromatographs running simultaneously (to save time). One for anions and one for cations.
Each sample runs anions and cations. So a Dionex ASM autosampler is a simple and affordable solution for my needs. Since this AS uses external injectors, I imagined that I could have one injector's out-port go into the in-port of the other injector and have them both loaded up at the same time.
The question is, how could I program both chromatographs in peaknet to make use of the same load cycle of the autosampler and have them run in parallel after that, and then load up the next sample etc.
any ideas would be welcome.
